I have a 2009 Silverado with an A/C issue - it blows ice cold at idle, but at any rpm above idle, it loses the a/c command signal every few seconds and will blow increasingly warmer air until the command returns and the clutch engages again. My pressures appear to be ok, and I'm suspecting it's the Refrigerant Temp Sensor, but it's such a pain to replace that I'd like to verify its output, if possible, before diving in. I can't seem to find any reference to that sensor in the VCM Scanner, however. Is there any way to get a reading from it?
