Results 1 to 5 of 5
Thread: i bought anHP Tuner E41 L5P and i have some questions
    Dec 2022
    5
    I bought an HP Tuner E41 L5P upgrade/unlock kit used with 8 credits for the E41
    I want to use it to tune an E38 ECU if I don't use the upgrade box can I just use the MPVi3 on that ECU after buying credits?
    I loaded HP tuner and was able to read the ECU pull codes but don't want to spend on credits if it's not going to work
    I did open a support case but they said it would not work for that ECU but I prob did not make myself clear
    thanks
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,432
    yes you should be able to tune your E38 ecu with your MPVI2/MPVI2+/MPVI3 device without issue.
    Aug 2024
    1
    Have you confirmed whether the 8 credits that came with your used HP Tuner E41 L5P kit are transferable and can be used for tuning an E38 ECU?
    HP Tuners Support
    (foff667)
    28,432
    Quote Originally Posted by ferry2 View Post
    He stated "can I just use the MPVi3 on that ECU after buying credits?" I think he knows he needs to purchase credits in this case.
    8,974
    Repeating whole oddly-worded phrases from the first post like that, with a very low post count, is a hallmark of one that's going to lie low for ~3 days then get edited to add a link to some dumb phone clicker game (usually with a *.io TLD).
    GM Gen4 Injectors v2.1.xls
    ChatGPT is the end result of someone assuming that if they gather up a large enough pile of sh*t it will spontaneously generate a pony.
