Launch Control Configuration
I'm trying to get the LC logic to use a fuel cut instead of the standard throttle cut, has anyone figured out a way to do this? I've tried messing with the offset for fuel cut but had no luck. I don't want to use the neutral limiter as I would like it to be controlled under the launch logic and have the ability still to turn it on/off.
Car is a 2022 Fiesta ST 1.5 3 cylinder (Never brought over to the US, EU model).
Bump, someone must have had a play with it.
