E67 Command Throttle Position for Crank
Hi, I have an E67 running a LY7. On the scanner I see that it is commanding about 18 deg. throttle opening during crank and it's cranking longer than I would like. I'd like to try a smaller throttle opening but I can't seem to find the map that controls this parameter. In the "Electronic Throttle" section there are maps but they just seem to control the rate of opening vs. accel. pedal input. I've looked at all the other sections but can't seem to find anything related. I would appreciate any help.
Also, as I posted in the Misc. category, while the engine starts and runs, the VCM scanner is not detecting RPM, inj. pulse width, and some cam sensor related codes that I can read on a different scanner. Ideas?
