Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Anyone use an IC Chiller System?
  1. #21
    Quote Originally Posted by LilSick View Post
    send me the current tune
    ill make it so your fans always be on high so you can test temps
    testing the outside of the hose is shitty way to do so but whatcha gonna do???
    its not cross flow design
    its not blocked by bumper (i would not mess with that, looks like it would get plenty of air across it)
    Thanks, here ya go:TH_Next_Tune-09102024_Spray-Cam_Combo_Knock-Adjust.hpt
    I think I will drill and tap the straight couplers so I can install thermistors into the lines on each side. That'll allow me to measure the inlet and outlet fluid temps and eventually connect them to whatever gauge solution I land on.
    2023 Dodge Durango R/T (5.7L) with Tow & Go Package (build thread)
    Gen 5x Whipple 3.0L Supercharger
    Smooth Boost Electronic Boost Controller
    SRT 392 Air Intake Conversion
    92mm Hellcat Throttle Body
    Mighty Mouse Mild SRT Catch Can Setup
  2. #22
    Jan 2022
    fountain valley
    1,230
    sup
    [email protected]
    don tanklage
  3. #23
    sup
    Weird ... Uploading it again, maybe it got corrupt?TH_Next_Tune-09102024_Spray-Cam_Combo_Knock-Adjust.hpt
  4. #24
    Aug 2006
    5BA8
    4,401
    Quote Originally Posted by Stoopalini View Post
    I'm getting the same thing with this one.
    EFI specialist
    email=[email protected]
  5. #25
    Really weird. I have no issue opening it on my end ....
    What version are you guys on? HP Tuners had to add support for my OS when I started this journey. So I imagine previous versions won't be able to read it.
  6. #26
    Jan 2022
    fountain valley
    1,230
    open a ticket
    [email protected]
    don tanklage
  7. #27
    I'm not getting that error, so I'm not sure a ticket is needed. Wouldn't a ticket be used for them to add support to Beta?
    This isn't a bug in the software, and is perfectly normal.
    When you read your PCM and then try to open the file with VCM Editor and receive this message here's what you should do:
    1. Email the .hpt file as well as a VCM Suite infolog while connected to the vehicle in question to us at support at hptuners.com
    2. we will review the file for integrety and if the checksums are correct & not disabled, missing or corrupt we will send you an update as soon as possible to fix this issue.
    3. the fix will be included in all future shipped software and updates.
    Fixing these issues are #1 when it comes to support so you can be assured that you have our full attention when we receive one of these emails.
    This error is most common on Ford, Dodge & GM Alloytech(Bosch) pcm's & usually means its a new operating system we have yet to come across & we need to map the calibration for your use which can take several days or longer depending on the complexity of the operating system.
    Thanks for your understanding and patience (we know what it is like to get something new only to have to wait another day to use it).
    Support
    I just downloaded the file which I uploaded, and saved it as a copy ... and had no problem opening it in VCM Editor 5.1.3106 Beta.
    What version of VCM Suite are you on? Initially, VCM did not support my OS and I opened a ticket back then. It took them about 2-3 weeks to add support to Beta for it. If you're running a version which is before they added support for this OS, I can see this error happening.
  8. #28
    BTW: This idea of HP Tuners needing to add support for this OS is another thing which could mean they got something wrong in the mapping thus impacting the airflow model and UI mapping in VCM Editor.
  9. #29
    Jan 2022
    fountain valley
    1,230
    i suggest you go back to 5.0.4 and do a read
  10. #30
    5.0.4 does not support my OS. That's what I was originally running when I submitted the ticket to have it added.
    Before adding support:
    After adding support:
  11. #31
    Aug 2021
    Indianapolis Area
    316
    Mine opened fine!
    I just sent an email to you Stoopalini.
    Thanks.
