Results 1 to 7 of 7
Thread: widebands
    Sep 2021
    Kentucky
    1,818
    widebands
    Post your wideband of choice for data logging and dyno use, please include the amount of use/abuse seen.
    Currently: afr500v2 analog with ntk cal grade sensor/v2 can with bosch 4.9 for 07+ na builds
    Dual 14point7 spartan 3 lite v2 with 4.9 for reference on dyno
    Tune 2-4 vehicles per week
    Dec 2019
    MS
    1,170
    Ive been using LC2 and LM2 with 4.9 bosch sensors for several years.
    Seems the 4.9s usually last about 15-20 vehicles before going bad.
    some weeks are only 1 tune, max is 8 a week.
    I like the NTK with the Holley ECUs.
    North Carolina
    4,769
    I've had great luck with AEM. Especially the CAN version. I wouldn't recommend another.
    I have them setup modular to go from car to car.
    Sep 2021
    Kentucky
    1,818
    I must have had some great bosch sensors. I was tuning 100+ on the same sensor when i ran a 30-0300. I would retire them about once a year mainly due to being in misfiring vehicles. Im not expecting the dyno sensors to last but so far the one ive used has been great.
    Advanced Tuner abc's Avatar
    Jan 2024
    927
    I'm not a pro, but I do have three different vehicles with a total of 4 uego's LSU 4.9's for the last 4 years (knock on wood) and have not had a failure yet. Two of them are controlled by AEM and the other two are on a Holley system. I imagine sensor failure is the easiest to spot, but sensor drift on the other hand may be a whole other bag of worms to contend with and this is where ignorance may be bliss?
    Do you think the location of the dyno sensors plays a significant roll in failure rate? Such as, if your gonna put it in the tail pipe, don't put it in there until the exhaust is thoroughly warmed up?
    Sep 2021
    Kentucky
    1,818
    There is quite a bit of condensation that builds up between logs and during a short cool down sometimes. Being at the tailpipe ive seen the clamps soaked in water after a few pulls even on vehicles drove in that were already warm. Some of these large mufflers on trucks are the worst.
    North Carolina
    4,769
    Tail pipe sniffers will kill widebands. Make a couple pulls without it first.
