Man this thing idles rough now that I've increased idle timing back to stock. Fuel trims at idle are under 4% error. Not great, but close enough that I'm thinking something else might be causing the roughness. I've been running in VVE only for the time being as I've been trying to dial that in. I've not had a ton of success with the MAF + VVE simultaneous method. Could be user error though.
Attached a 10 min idle log and the tune if anyone has got any ideas. My VVE table is ugly because I've only been working in the idle region for the time being. Also attached the stock tune for comparison. Ignore the date in the tune file name - I need to update that. Thanks!
Cringer - so SS air + P and I is what is controlling the throttle body then? And my dynamic air is reacting to that and controlling my fueling appropriately?
Edit - Also attached for reference a log from when I had the timing pulled at idle to 11.5 deg. It's the drive from Dairy Queen log. The first half of the log is all idle while I'm in the drive though, and I really liked how it idled here. This is what I'm shooting for, but without 22% throttle and super low timing
08232024_Idle_After_Brake_Booster_Replacement_3_VE_ONLY_3.hpt
IdleLog3.hpl
08022024_StockTune.hpt
DriveFromDairyQueen.hpl
