E38 cranks no start. Factory ecu on 2007 suburban 2500 6.0/4l80e no spark and no injectors firing. Has cranking RPM and fuel pump is working as it should, have pressure at the rails. I got the truck missing drivetrain and wiring and modified a 2007 1500 5.3/4l60e engine harness to fit. Ecu is original to the suburban and HP tuners confirms this matching vin.
Fuel pump some in tank pump and tune is changed for no FPCM already when looking over tune.
All 3 grounds are in place on harness, coils have 12v keyed and good ground, injectors have 12v keyed.
Any ideas what to check next? This gen4 is new to me, always worked with gen3 on modifying stuff.
Here is everything I did to modify the harness
https://docs.google.com/document/u/0..._U/mobilebasic
