Results 1 to 9 of 9
Thread: How to change MAF Calibration Hz Scale
    May 2008
    Wichita, Kansas
    177
    I have a 2000 Corvette and am putting a LS3 into it. Ill be using a LS3 blade style MAF and notice in the LS3 tune the scale starts at "0", ends at "15k", the LS1 tune file it starts at "1500" and ends at "12k". Is there a way to alter the scale so I can input stock LS3 values into my LS1 tune?
    2000 FRC Corvette with LS3 Swap
    Nov 2017
    2,768
    Are you using the exact stock intake setup from the LS3? If not, it isn't going to matter since the LS3 values will be incorrect.
    Jan 2015
    Arizona
    1,267
    Quote Originally Posted by Ls1c5vette View Post
    youll have to tune it.
    tune the MAF
    tune the VE
    tune the timing
    etc
    Aug 2006
    Arizona
    365
    Can't change it.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    May 2008
    Wichita, Kansas
    177
    Similar custome setup. Maf will be in stock ls3 location.
    Nov 2017
    2,768
    Not sure what this means. It doesn't take much of change at all for it to be a totally different calibration.
    Aug 2006
    5BA8
    5,454
    You can't change the axis of the graph. You'll have to dial in the airflow numbers to fix the GEN3 table. The numbers will be drastically different. It likely won't even run with the card style MAF on the GEN3 table.
    EFI specialist
    email=[email protected]
    Senior Tuner 04silverado6.0's Avatar
    Sep 2021
    Kentucky
    1,839
    I usually copy the best i can values from a file that matches the maf im using. Doesnt always directly cross but you can get it close.
    Jan 2024
    Windsor, CT
    36
    I'm running a C6 card MAF in my C5, using a C6Z air intake setup. You can try copy/paste my MAF table and that should get you in the ballpark, enough to run it, and tune your tables from there.
