Results 1 to 7 of 7
Thread: 80lb Injecotrs WAY Rich
    May 2014
    30
    Put a set of Deka 80 injectors in a 2002 Mustang GT today. Data is good as far as I know and its running insanely rich. Trims are pulling 50% between them.
    From some research I see others in the past experiencing the same issues without a resolution. Is it possible that that I'm hitting an injector size limit? I did find this that talks about scaler when using big injectors or when exceeding the MAF airflow with the EEC-V.
    http://www.efidynotuning.com/fuel.htm
    Oct 2007
    Crawfordville, FL
    2,583
    I've never personally had an issue. Try lowering the minimum pulsewidth and see if it gets under control. A quick test to see if this is it... set minpw to 0.
    Eric Brooks
    HP Tuners, LLC
    May 2014
    30
    I will try to drop the PW to zero....but it's not just an idle thing...it goes across the entire map range. STFT and LTFT both running nearly -25. The article I linked shows the limits on injector size for the EEC-V and the 75lb/hr is definitely over the limit.
    May 2014
    30
    Tried minpw=0 with no change. I will try scaling the tune when I get time. Hopefully the tables are available.
    Attachment 150751
    Advanced Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    210
    Quote Originally Posted by Polonda View Post
    Post your specs & tune you need to scale injectors
    Western New York's Performance Headquarters
    716.830.0506
    Aug 2006
    5BA8
    5,276
    How is anyone supposed to know anything without knowing your complete specs and looking at your tune file? It's most likely a scaling issue. Need to know the engine specs, the MAF and need to see your tune file. 100% it's a matter of scaling the injectors correctly to the MAF.
    EFI specialist
    email=[email protected]
    Banned
    Mar 2022
    Indiana
    4,289
    Scale and watch min_PW as mentioned. Also, check your Deka 80 data against this. It is the most updated and accurate Deka 80 data available. Yes, the link is on the Gen III LS section, but within that file is a Ford data tab.
    https://forum.hptuners.com/showthrea...l=1#post796064
