Results 1 to 7 of 7
Thread: Misfire timing help
    Jan 2021
    17
    Misfire timing help
    Can anyone help me understanding misfire timing. And why My log files show it most of the run
    Jan 2021
    17
    log files and tune
    the non highway run skip to end
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    242
    Just diseable missfire
    03 cummins,175% flux injectors,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
    Jan 2021
    17
    Quote Originally Posted by MAIDENCR View Post
    Was not sure if that will affect anything or not , another question is why is it doing it?
    Sep 2018
    Quebec,canada
    242
    I dont know...but when active it will go in the missfire timing table....
    Jan 2021
    17
    Is anyone else just turning it off in there tunes?
    Sep 2023
    438
    Quote Originally Posted by Justin77 View Post
    The simplest answer is if it didn't do it before you started changing things in the calibration and does it after you've changed things, then it's something in what you did that's triggering it and easiest way to find what is is one table/parameter a time put it back to stock till you find what it is that's triggering it, or can just turn it off like mentioned above and not worry about it.
