Results 1 to 6 of 6
Thread: 6l80 Trans Slip 2-3 High RPM
    May 2024
    Mount Airy, MD
    37
    Out of the blue i have developed a trans slip when in high RPM's shifting from gears 2-3. Truck is a 2015 GMC Sierra 1500. I have shift timing reduced 20% in all upshifts except 5-6, torque converter apply/release disabled gears 1-4, all converter slipped zeroed out. Is their anything in my tune causing this or is their anything I can do to fix this? Will post tune file below. 2015 GMC Sierra FINAL MAF VVE.hpt
    Aug 2006
    Arizona
    365
    Have you checked your trans fluid level? Sounds like you may be 1/2 to 1 full quart low
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    14,061
    I agree, add a little bit of transmission fluid. It's okay to overfill them just a little bit.
    Also if that is a stock converter, we have learn that it's not a good idea anymore to zero the TCC slip completely. Still allow for 5-10rpm of slip as zero slip can hurt the stock converters.
    But if adding fluid doesn't help, it could be hurt if it has a ton of miles on it.
    May 2024
    Mount Airy, MD
    37
    How come the converters can go bad from zero slip?
    I will check the trans fluid levels, had trans flushed about 15k miles ago, truck only has about 68k on it.
    May 2024
    Mount Airy, MD
    37
    Quote Originally Posted by STAGEUP View Post
    Just checked it, my truck is backed into my driveway which is a slight uphill so I?ll set it in the garage and check in the morning because the dipstick just read full.
    Oct 2017
    Michigan
    65
    Quote Originally Posted by TSaleik29 View Post
    Its not simple to just check the dip stick. bring to trans operational temp and on level surface remove the overfill service plug. Let drip out and your done. Replace plug!
    I hate to say it but its possible your trans needs rebuild.
    Had mine rebuilt before 10k miles but my new stall is triple disc. so 1-3unlocked and 4-6 locked. Nothing special with tune just copied the HPT youtube video settings.
