Here is what I am looking to do, I have tried working with excel, but I lack some mad excel skillz to accomplish this. I am working on a spreadsheet that helps to tune your automatic shift points, but it involves quite a lot of data and being able to sift through it to properly setup the tables (Part Throttle (MPH), WOT (MPH & RPM), TCC Lock Up/Release (MPH)). I have done it successfully without excel, but I am looking to automate it and make it a simple import external data, excel calculates, then you copy and paste. Now what I need, without disclosing how it works (proprietary information ).
First:
With imported external data, how does one average certain values based on a second set of values. Say I have a lot of data on RPM ranging from 500 rpms to 6000 rpms, but I only want the average of the RPM column with 0% TPS values?
Second:
Using the same data, how do I go about getting the max value (of say RPM) with the TPS% value being 100% (or max value).
Third:
How do I create a pull down menu, or check box setting, to select different figures (trans ratios) that can be used in this spreadsheet?
That should get me started for now, but I will inquire agaion should I get stuck again. Thanks!
