Results 1 to 7 of 7
Thread: 2023 Polaris Ranger 570
    Mar 2024
    19
    I have been trying to tune a Ranger 570 but I can't seem to get it to go over 50 MPH. I raised the limiter to 100 mph but when you drive it you can tell that it hits a limiter. Any ideas on what I should try to get it to go faster? Thanks.
    Oct 2007
    Crawfordville, FL
    2,553
    Quote Originally Posted by 79 Bronco View Post
    Post the file.
    Eric Brooks
    HP Tuners, LLC
    Mar 2024
    19
    Here is the stock file and a file with raised rev, speed and torque limiters and with changes to make it open the throttle all the way
    Oct 2007
    Crawfordville, FL
    2,553
    I'm betting this is an OS that has farm mode, and it's enabled. Let me add those parameters today and you should be able to disable that.
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,553
    I was wrong about farm mode, but this OS does have a speed limiter that appears to be used compared to some that do not use it (cal'd out).
    Get the latest beta, and raise this up please.
    Eric Brooks
    HP Tuners, LLC
    Mar 2024
    19
    The drive belt broke on the ranger so I will have to fix that and then I can give it a try
    Mar 2024
    19
    here is the current tune I am trying to run and a log of a wide open pull.
    it seems like when it reached 47 mph the rpm dropped some.
    I don't know how exactly the desired load from torque works but it seemed to hang around 82% should it read 100% or does it not work that way?
