I need some help figuring out how to set the scanning parameters in VCM Scanner. I have a really good setup for my own car, but I would like to know how to set them up on someone elses car. Hopefully it is easy.
a. check out the sticky in each forum title "Configuration & Histogram repository" as they have a bunch premade for you.
b. check out the demo I made for standalone datalogging as it helps run you through the process http://www.hptuners.com/help/demos/s...onelogging.swf
c. check out the getting started sectino of this forum as it too has gobs of information concerning scanning including a scanner & editor quick start guide, again, right in the sticky.
Dude, you are awesome! I was hoping their was a repository.
