Results 1 to 3 of 3
Thread: Stroked 6.2 Cam choice guidance question
    Feb 2022
    Washington State
    57
    Hey all..
    I have put together a 6.2 short block with a 4" stroke and I'm looking for some guidance on which cam to use with it. It'll be in a Yukon XL.. I'll be using a stall converter and it's going to have a 'right sized' turbo on it. I'm leaning toward a Borg warner S362.
    Here's my criteria.. 1. Burn rubber 2. good street manners..
    Does anyone have a cam they've used in the past that works well with a heavy vehicle? I don't need to to rev out to 7K RPM.. I'd like mid-range power.
    What would be a good LSA for this engine?
    Dec 2019
    MS
    687
    Quote Originally Posted by chadtunes View Post
    Hey all..
    S362 is a pretty small turbo for a 415ci engine.
    What heads?
    Feb 2022
    Washington State
    57
    Quote Originally Posted by RDF1 View Post
    What heads?
    I'm going to send my extra set of stock heads to West Coast cyl and have them reworked to a 'stage 3' configuration with .560 springs, trunnion kit and whatnot.
    I have a S362 on a 366ci (6.0 ford) diesel engine and it gets to illegal speeds and or lights up the tires before 4K rpm. I forget what the AR ratio is.. I'm looking for a similar 'rowdy' mid-range power.
    I got the diesel engine right.. Gas engines are a different animal. I'm in the hand wringing stages of this build.. Lots of research.
