Originally Posted by
vthex
Update: On a E80a ECM, I dropped the values by 50%, results, cut a tenth off my 0-60 havent tested any other metrics yet, and it still dropped off torque pretty fast, BUT it was slightly later on in the rpm range around 5800ish i would get 290, Ive done a couple logs over the last 2 days, and results were pretty similar,@5600 the min torque was 294@5632 max was 310@5614.
Both could just be luck since i only logged around 40ish minutes of driving,
I will do more research to see how much i should change it, i will also log a zerod out table to see if there's any major change
