Results 1 to 10 of 10
Thread: 2008 5.7 Cammed Hemi tune
    Question 2008 5.7 Cammed Hemi tune
    Hi all just acquired my HPtuners MPVI3 and am trying to tune my cammed 2008 5.7Hemi in an 70 Cuda
    I am idling reasonably ok in P/N, but sometimes hunting for idle (mostly happens when reaching running temperature)
    Drives well on D, but dying at intersection/stops
    Can someone help with Tune files to start with please!!!
    Configuration:
    5.7 no VVT non MDS
    COMP Cam XFI 224/228 Hydraulic Roller Cam for Dodge HEMI 5.7L/6.1L 2003+
    Intake Duration 273
    Exhaust Duration 277
    Intake Duration at .050 Inch Lift 224
    Exhaust Duration at .050 Inch Lift 228
    Intake Valve Lift 0.547
    Exhaust Valve Lift 0.55
    Lobe Lift Intake 0.342
    Lobe Lift Exhaust 0.346
    A727 Tranny HPTuners set to Manual Transmission Enabled
    Only 2 O2 sensors in Exhaust Manifold ... 3" straight exhaust
    OEM Gas pump
    Configuration:
    5.7 no VVT non MDS
    Intake Duration 273
    OEM Gas pump
    are you looking for a base map or somebody to tune it for you ?
    Base tune would be good ...
    Jun 2022
    Canada
    65
    I might start with Min Air Flow table in the bottom three columns. Either Add or subtract and see if that helps.
    Jun 2021
    47
    post your stock file and ill make you one that should be close
    Hemicuda original.hptHemicuda 1.hpt
    Thanks JohnnyFW
    Attaching two files
    Hemicuda original is the stock file
    Hemicuda 1 is an attempt that was slightly better but still same symptoms.
    Quote Originally Posted by JohnnyFW View Post
    Thanks JohnnyFW appreciate the support
    Quote Originally Posted by StupidJeep View Post
    Thanks SJ will give it a try also
    Jun 2021
    47
    try this these ve tables are for comp cam stage 2 you will still need to adjust them but it should be pretty close i think
    Hemicuda 2.hpt
    Hemicuda 2.hpt
    Thanks Johnny will load it up and let you know
