I'm working on my bros car and it lost communication with the tcm, trying to figure out where the power to the tcm comes from, i've looked everywhere and cant fin a diagram. your help is appreciated!!!
what kind of car or truck is the transmission in?
2012 chrysler 300 awd! thanks for the reply bro.
should have a yellow/red wire coming from the TIPM. Its fuse 57 on my truck, not sure which on yours but should be labeled on the TIPM cover. Its a 20 Amp fuse. And then you will also have a Pink/White wire in the tcm plug for Ignition Run/Start Control which is coming from the BCM. Aside from those two wires, you should just have a ground wire (Black) and 2 canbus wires (Violet/White and Yellow), 2 data bus wires (White/Brown and White/Orange), and finally a transmission park signal wire. Mine is Yellow/Dark Blue and comes from my Radio Frequency Hub mounted on the rear cab wall right in the middle behind the console splitting the 2 rear seats. Those are the 8 wires you need to control the trans/tcm.
"1MEAN16" Silver/Black 2016 Ram CCSB NA 400ci Stroker (399.4ci)
+1.5cc Diamond Forged Pistons w/ 13.1/1 Compression on E85
Forged 4.08" Stroke Crank, Ported Heads w/ Titanium 2.12"/1.61" Valves
Custom Cam 235/249 .619/.637 111.5LSA 110 ICL
Ported Hi-Ram Intake, NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
Tx Spd 2" Long Tubes, ATI SD 15%UD, Ram TRX K&N CAI
Dual 525 Pumps, Demon 700cc Inj, Fuel Cell in Bed
Built 8HP90 w/ 4000 stall/Detroit Tru-Trac/410 Gears
