Page 13 of 14 FirstFirst ... 391011121314 LastLast
Results 241 to 260 of 279
Thread: getting knock under wot
  1. #241
    Aug 2024
    Texas
    157
    In that last log the P0327 low voltage knock sensor code was present.
    I believe the dtc p0327 wasn't switched over to mil on 2nd error. here is one after I corrected that. The first one is what it looks like after a couple of days. The second one no knock is what it looks like after I write anything into and go drive it. Its like it resets and a couple of days later its back. You can tell when it comes back to it goes into buick le sabre mode.
  2. #242
    When you built the motor did you buy new sensors and a new harness?
    https://www.rockauto.com/en/catalog/...on+sensor,5108
  3. #243
    Aug 2024
    Texas
    157
    All Brand new and torq to 15lbs. But what’s weird is it doesn’t do it till a couple of days later.
  4. #244
    What brand knock sensor? Weather coming in to play? I am in Texas, we are getting some cold-hot-hot-cold-hot stuff here in Austin area. I am sure there is some kind of test process for the knock sensor... someone saying buy the service manual, maybe he was right. HA.
  5. #245
    Aug 2024
    Texas
    157
    Quote Originally Posted by DodgeZ View Post
    They are delphi. I do the hammer test with them to make sure they work properly before I even install them.. The Ac Delco's are the ones I've had issues with not working at all. I've done some reading on them and quite a few people even on here just turn them off because its a issue with the gen 3s. I feel like if its going to knock it would do it immediately and not wait a couple of days after I write a file.
  6. #246
    Mar 2022
    Indiana
    3,792
    Did you use RTV on the knock sensor grommets including where the wire enters? Sure all grounds are good as measured with a meter? Engine running, voltmeter set to vdc, check between ground and negative battery terminal. Should be nearly no voltage between the ground and ground post.
    Look into that before disabling the low voltage dtc's.
  7. #247
    Aug 2024
    Texas
    157
    vehicle running no volts between the grounds. I'm not getting any dtcs though I'm just getting kr.
  8. #248
    Mar 2022
    Indiana
    3,792
    From what I've seen the P0327 code has been present in the logs registering KR. It's even "knocking" on the low octane table.
    Post #6 and #11 here:
    https://ls1tech.com/forums/generatio...ml#post8685614
  9. #249
    Aug 2024
    Texas
    157
    even on this one? shouldn't be i haven't gotten any codes recently or even now
  10. #250
    Mar 2022
    Indiana
    3,792
    Yeah man even that one. Both P0327 and P0332. No CEL illuminated because they are pending. In the log at the bottom left click the "Log Details" tab.
  11. #251
    Aug 2024
    Texas
    157
    aww ok I see well let me start this process all over again. here is one for today no knock.
  12. #252
    Just a reminder, the flex OS tune wasn't converted to the speed density enhanced mod. So it will be using the low octane timing. Though that maybe good while you figure out the knock sensor issue.
  13. #253
    Mar 2022
    Indiana
    3,792
    Quote Originally Posted by smasher View Post
    That's right. You clear the codes and no knock. Eventually the codes come back and so does KR. Run through the diag procedure so it stops happening.
    It's on the low octane table. I see DodgeZ commented on that. Still, it'd be useful to see start logging Knock Learn and Burst Knock.
  14. #254
    Aug 2024
    Texas
    157
    so under os do I need to apply those mods? and the 2 bar as well since I am using a 2 bar?
    Edit it doesn't allow me to apply both mods for some reason or another. Is this what I'm supposed to write entire to after this?
  15. #255
    write entire
  16. #256
    Mar 2022
    Indiana
    3,792
    Using a 2bar what? This is a 1bar setup. That's the type of MAP sensor.
    Post #222 is the most recent FlexFuel revision. Here's that with 1bar SDOS applied. Write-entire.
  17. #257
    Aug 2024
    Texas
    157
    what did you have to change to make it a 1 bar?
  18. #258
    Mar 2022
    Indiana
    3,792
    Are you needing clarification on what is meant by 1bar and 2bar?
  19. #259
    Aug 2024
    Texas
    157
    No just wondering how you changed it?
  20. #260
    Mar 2022
    Indiana
    3,792
    By clicking the buttons where the arrows are pointing then following the instruction prompt.
