Page 5 of 14 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 279
Thread: getting knock under wot
  1. #81
    Banned
    Mar 2022
    Indiana
    4,289
    Any time PE enables, any time you go WOT. What is the number on the gauge?
  2. #82
    Aug 2024
    Texas
    174
    ok so from just wot mashing it stayed around 12.60 and from a stop it dipped into the 11s but was kind of all over the place till it leveled out around 12.60
  3. #83
    Banned
    Mar 2022
    Indiana
    4,289
    That's what I figured. Problem is wideband in the log is indicating 13.6-14.1 during PE. It's not fuel pressure because of the abrupt transition in AFR error only during PE. What's weird is the wideband indicates stoichiometric during CL like it should.
    What I'm saying is the wideband in the log isn't matching the gauge. Something is going on with your scanner config or wiring to the MPVI ProLink.
  4. #84
    Aug 2024
    Texas
    174
    I can go do another run and make sure it matches. or see if I can find a solution. unless you have any ideas?
  5. #85
    Banned
    Mar 2022
    Indiana
    4,289
    I don't have an explanation. If it was me I'd run serial-usb and not have to worry about analog signal problems. You'd have to order a breakout connector and the right cable for that. Could try analog A/C or EGR for now I guess.
  6. #86
    Nov 2017
    2,792
    Alvin recommends videoing the screen and gauge at the same time so it can be adjusted.
  7. #87
    Banned
    Mar 2022
    Indiana
    4,289
    Yeah don't though. If it's wrong you're going to be cobbling the math to make it right. I hate cobbling. Then you have to wonder is right actually right.
  8. #88
    Aug 2024
    Texas
    174
    Well I'm open to ideas or suggestions on how to get this to work.
  9. #89
    Nov 2017
    2,792
    Id video it anyway just to get a better idea of the scope of the problem.
  10. #90
    Banned
    Mar 2022
    Indiana
    4,289
    Quote Originally Posted by smasher View Post
    USB to Serial cable with FTDI chipset. DB9 serial female breakout connector. Amazon.
  11. #91
    Banned
    Mar 2022
    Indiana
    4,289
    Ah. Use a different channel. I've never used ProLink btw.
    "In VCM Scanner go to External Inputs > MPVI2 > Pro Link, you will then be able to add the PID “MPVI2 SP A/D Input 1” or “MPVI2 SP A/D Input 2."
    https://www.hptuners.com/pub/Pro_Link_v1.pdf
  12. #92
    Aug 2024
    Texas
    174
    yea that's how its setup currently with the prolink. probably just have to throw down on the serial port method. Is this all I need?
  13. #93
    Banned
    Mar 2022
    Indiana
    4,289
    Need the DB9 female breakout connector, too.
  14. #94
    Banned
    Mar 2022
    Indiana
    4,289
    I'm guessing since the motor has been in and out that a ground wire wasn't put back somewhere.
  15. #95
    Aug 2024
    Texas
    174
    ok these two items? does this hook from the wide band straight to the computer? seems pretty easy and better wasn't aware that you can do it this way otherwise I wouldn't have wasted money on the prolink.
    USB to RS232, USB Serial Adapter with FTDI Chipset,USB 2.0 to Male DB9 Serial Cable
    DB9 Breakout Connector to Wiring Terminal RS232 D-SUB Male Serial Adapters Port Breakout Board Solder-Free Module with case(Female Serial Adapter)
  16. #96
    Banned
    Mar 2022
    Indiana
    4,289
    The manual for the wideband kit will show you what wires go into which pins on the breakout connector. The one that can be closed back up and has the wire strain relief is what I use.
    Drivers for FTDI should automatically install when the serial-usb cable is connected.
    In scanner use AEM - AFR.
  17. #97
    Banned
    Mar 2022
    Indiana
    4,289
    Real quick though. How come scanner doesn't show MPVI A/D Input in the log? It's MPVI2.2->AEM 30-....
    Are you absolutely sure about the channel before you go buying stuff?
  18. #98
    Aug 2024
    Texas
    174
    once you make the mpvi a/d you have to transform it to the sensor you want to use otherwise it's just voltage
  19. #99
    Banned
    Mar 2022
    Indiana
    4,289
    That's no problem. I'd prefer raw signal. Do another log that has WOT so I can check it.
  20. #100
    Aug 2024
    Texas
    174
    ok here it is. I see why the pro features are free now lol.
