Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: 2011 gmc 6.2 /4l80e help
    hi all
    my dad has a 57 belair with a 2011 6.2 /4l80e
    e38
    t42
    dod is disabled
    vvt is zeroed out
    car seems to idle great but falls flat on its face under load
    i tried with maf pluged in and not pluged in no real difference
    ltft seems to go +25% out of no where
    please help
    Aug 2006
    5BA8
    5,404
    Post the tune file.
    Put a fuel pressure gauge on it. One you can tape to the windshield so you can watch it while you drive.
    EFI specialist
    email=[email protected]
    fuel pressure stays at about 60psi
    Aug 2006
    5BA8
    5,404
    Quote Originally Posted by laurieandmike View Post
    That's what everyone says and around here it's code for 'I haven't really checked it, I'm assuming'. Your MAF table is already doubled. Granted they do need recalibrating when you move them like in a swap vehicle, but with it being doubled I'd suspect low fuel pressure.
    You aren't logging MAF Hz or injector on time. Both are need for diagnosis and tuning.
    Also, about halfway through your scan you lose RPM. Looks like it was still running so must be a scanner glitch.
    EFI specialist
    thanks for reply
    i keep checking fuel pressure but will take a video
    maf was bought new but i am not a tuner by no means lol
    how do i add channels like hz or injector
    yes rpm justed stoped
    the speed moves even in park
    thanks again for the info
    Aug 2006
    5BA8
    5,404
    thanks for reply
    If the speed moves in park you got issues LOL
    Post a picture of the cold air intake and MAF location.
    EFI specialist
    will get a pic
    will also see if the vss/iss is pluged in backwards or not
    Nov 2006
    North Carolina
    4,769
    This is dead lean any time you are getting on it.
    This also sounds like ISS / VSS are crossed.
    could be also.. if the VSS wires aren't a twisted pair. VSS will read noise otherwise.
    here is last scan
    vss wires were backwards
    still falls flat on its face under load
    Nov 2006
    North Carolina
    4,769
    Still very lean when you are getting on it.
    where should i go from here?
    i am going to try to get the fuel pressure gauge setup so i can see it
    no codes
    thanks againfor reply
    Aug 2006
    5BA8
    5,404
    no codes
    First step is checking and verifying that the fuel pressure is good at all times. Not just sitting still idling, but under power, moving, etc.
    EFI specialist
    405
    3,182
    FP is the #1 issue I see in swaps. #2 is probably trying to run it with open exhaust close to the O2 sensors. But I just want to hear it run and start tuning it. Well finish the build first.
    Aug 2006
    5BA8
    5,404
    Quote Originally Posted by 2xLS1 View Post
    Yep and for me not just swaps it seems like everyone just ASSumes their vehicle has adequate fuel pressure. It's the "nah that ain't it" attitude.
    EFI specialist
    405
    3,182
    OEMs go to a lot of trouble to engineer and manufacture robust fuel systems in their EFI vehicles. DIYers usually don't when it comes to a swap.
    Aug 2006
    5BA8
    5,404
    I agree but that still leads to people ASSuming everything is fine fuel system wise.
    Same thing applies to "all new parts" syndrome. "Fuel pressure is fine. It's a new pump, all new parts".
    EFI specialist
    Tuning Addict
    10,887
    "I opened the hood with it running and looked at the GzYcsFocusqp* chrome polished billet aluminum gauge I keep screwed onto the fuel rail and it was somewhere right around where it's supposed to be, so pressure isn't the problem."
    * Yes that is a real 'brand' name one of the Chinese drop-shippers uses on Amazon.
