Results 1 to 6 of 6
Thread: 17' Truck Norris 5.7 Idle Surge and TPS issue
    Jul 2024
    2
    I have been working on my truck that I installed the BTR Truck Norris Cam for the 5.7 and it has been a fun journey with the install and now trying to get it to run how I want to. I have been working on VE for a little bit to get it close so I can drive it. With the current tune it drives decent, pretty smooth for during driving, getting an average of 16mpg. I have a few hiccups I'm trying to work through, but I haven't been able to get them resolved. There is a surge in idle while in gear that is about 200-300 rpm sweep and it rocks the truck pretty good. Also I noticed this evening that the throttle isn't opening past 76 percent. If anyone could point me in the right direction I'd be grateful.
    Advanced Tuner Spray-Cam Hell-Ram's Avatar
    Aug 2021
    Yorktown VA
    251
    This should drive a little better....
    "1MEAN16" Silver/Black 2016 Ram CCSB (4592lbs) NA 398ci Stroker
    +6cc Mahle Dome Pistons w/ 12.8/1 Compression on E85
    Forged 4.08" Stroke Crank, 224cc AFR Heads w/ Titanium 2.165"/1.62" Valves
    Custom Cam 220/237 .627/.589 108 LSA 103.5 ICL, 105mm Hellcat TB
    Ported Hi-Ram Intake, NXpress Hi-Ram NO2 Plate kit w/125 Shot(4 sec)
    Tx Spd 2" Long Tubes, ATI SD 15%UD, Ram TRX K&N CAI
    Dual 450 Pumps, Deatschwerks 1000cc Inj, Fuel Cell in Bed
    Built 8HP70 w/ 3800 stall/Detroit Tru-Trac/410 Gears
    Jul 2024
    2
    Little better is an understatement!!!! That opened a whole new world that I didn't know this cam could do. Many thanks!!
    Aug 2021
    Indianapolis Area
    436
    Quote Originally Posted by 17cammedram View Post
    Could you share CAM specs?
    DodgeBoy.
    Email / Remote Tune: [email protected]
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    2,292
    iirc BTR cam with similar to stock 6.4 intake lobe, way tight lobe center, <110, and slightly larger exhaust numbers
    Jan 2022
    fountain valley
    2,292
    Quote Originally Posted by DodgeBoy_8HP View Post
    ***downloaded from the internet - ymmv
