Results 1 to 11 of 11
Thread: solenoid a issue 4l80 swapped silverado. turns on as soon as key is on
    Angry solenoid a issue 4l80 swapped silverado. turns on as soon as key is on
    2000 Silverado 2wd 1500 with a 07 4l80 4wd swapped. did segment swap. have ict adapter. everything worked great until coming back from a vacation. truck shifted great
    came back and the truck wanted to hold 1st gear til like 3500 rpms then shift to 2nd and immediately shift to 3rd. new solenoids and tcc etc. new internal harness. new ignition harness
    Solenoid A is turning on as soon as key is turned on. wont turn off with command. solenoid b will command no problem. i can command 2nd gear while driving no problem.
    I've checked all wires, grounds, connections a million times. idk if the last time i messed with my tune i messed a setting up with torque management or if my pcm is shot.
    originally thru a p0753 code
    Truck drove great before but i did mess with the tune a little before i left and drove it once and all seemed good.
    orginal tune segment swapped 1111.hpt
    After going thru my tune I noticed desired torque under torque management is showing 100 percent immediately. But 2 separate segment tunes I have with matching operating number are both zeroed out all the way. Could this be causing an issue forcing the trans to turn the solenoid A on since it has it starting at 0 rpms. Attached is a pic of the graph
    Aug 2023
    SoCal
    649
    Shift solenoid A is supposed to be grounded as soon as you start the engine. The computer needs to ground that solenoid control wire in P/R/N and in first gear. It then turns it OFF to command second gear.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
    Quote Originally Posted by TransGo Robert View Post
    But I should still be able to command it off ? I also did install your kit while replacing all the solenoids. What?s weird is I can?t command it off or anything.
    Aug 2023
    SoCal
    649
    When you say you can't command it off, do you mean that you see on your scanner data that it is not commanding it off when you asked it to, or do you mean the command changes on the scanner but the solenoid control wire remains grounded?
    Robert Moreau
    TransGo
    Yes. It shows it on hp tuners turned off when I command it but the solenoid isn?t doing anything .turning on or off. Hptuners shows it off when the key is on. No clicking or anything from solenoid a. I can do a 9v battery test and it?ll click. I have an entire extra harness trying to test new solenoids outside the trans just to get them to command. B works no issue. I?m unsure if tcc solenoid does anything when commanded. The truck was holding first gear the. Shifting to 2nd at like 3500 rpms then immediately shifts to 3rd. Original code was a p0753. Truck drove great before sitting for a week.
    I appreciate your responses
    Aug 2023
    SoCal
    649
    Ok hook up a voltmeter to the control wire for SSA at the computer end and unplug the computer. Then turn the key ON and see if you have full battery voltage or not. It needs to within 0.25V of what you measure across the battery under the same conditions. If not, tell me what you have and we'll take it from there. If you do have full B+, then plug the computer in, start the vehicle and see what you have in park as well as in drive at a standstill and report your findings.
    Robert Moreau
    TransGo
    ok. i will get that this weekend. currently have the pan empty of fluid so i dont have to drain again. i do alod have another pcm coming as it was one of my final options i could think of. thank you.
    Aug 2023
    SoCal
    649
    Ok no problem, you can do the testing with the pan empty and engine off. Just make sure that when you turn the key ON that you see on your scanner data that it is turning SSA ON.
    Robert Moreau
    TransGo
    Replaced the pcm today and reprogrammed and segment swapped my tune and all is good . Trans shifts great again. Idk what happened or what I did but I?m assuming I bricked it or it fried somehow while sitting for a week and half
    I appreciate your help and suggestions
    Aug 2023
    SoCal
    649
    Glad you got it fixed, thanks for taking the time to post the fix.
    Robert Moreau
    TransGo
