So all pressure and volume stock? Only adjust shift timing and torque adder?
Heres my tune since I tried Alvins advice. let me know what ya think when you get a chance. Ill try it in the morning.july241.hpt
Here is a couple logs from this morning after the changes. It actually feels really good, minus the clunkiness of the stock downshift settings. Ill fix that. Is the 2-6 still slipping? I dont know how to view that in the log on the graph
24-10-05 09-31-33.hpl24-10-05 09-06-55.hpl
Some of the 1-2 shifts are better some are quite worse, mostly the ones under lighter load. But it will take a while to adapt and fine tune the shifts so it might clear up some. It's on borrowed time anyways but if you can get more time out of it by tweaking the tune why not. I use a math channel graph the actual gear ratio so it makes it easier to see what it is doing.
Here's a screenshot of your 1-2 shift under light load, followed by a screenshot of a stock shift in a bone stock engine, transmission, and tune from a 201414 Silverado 5.3L
Now as you can tell the time it takes to make the shift is much shorter in yours because of the changes in the tune and you make more torque then stock, so the comparison is not all that great but it does show you the difference if you look at the bottom yellow trace showing the ratio change you can see what a nice shift looks like vs your bumpy one. You will also notice that were I have the cursor when the shift is finally done in both screenshot, that in yours the commanded solenoid output pressure needs to go about 10 psi higher to finally be able to complete the shift. You have more load then OE as I mention, so it is expected to have to go a tad higher, but that much tells us the 2-6 is struggling quite a bit.
The next two screenshots are under higher load, again first screenshot is your 1-2 shift the second one is from the same stock vehicle as above.
In this one you can just how much of a struggle it is to get the 2-6 to clamp down enough to finally complete the shift. The load is much higher so it shows the problem more of course. You can see now that the shifts never gets completed until the computer jacks up the solenoid desired output pressure just after the cursor to 90 psi to solve the problem.
There were no 5-6 shift made under steady throttle, just about all of them happen on lift throttle, so I can't say if the flare 5-6 you said you had at times is corrected or not by the changes you made in the tune.
Last thing, in case you wonder how come the 1-2 is not drastically worse now that your line is commanding to generate only roughly 220 psi while it was set to generate roughly 270 psi before, that's because the 2-6 never get to see full line unlike the other elements in the unit. Also line does very little in those when it comes to shift feel and timing, it only really makes a difference once the shifts are completed for how much load the elements can hold (except for the 2-6 because of what I mentioned). The only way to get full line pressure to the 2-6 is to modify the transmission internally using our TOW&PRO patented technology.
Robert Moreau
TransGo
I will get another log tomorrow. I upped the oncoming pressure some for the 1-2 and adjusted the inertia just slightly. And made sure the adapts reset. And it gets better the more I drive it. I am adjusting the 2-3 as it shifts super hard. And then I?ll get another log and see if that looks any better. I?ll have the parts next week anyways so I?ll be ready lol. I?ll probably get the kit you guys sell also.
I adjusted the 1-2 oncoming pressure slightly, the inertia for the 1-2 and the 5-6. I completely wiped out the adapts this morning at work with my GM scan tool. Test drove it and it seems to shift great. I havent had a chance to get a log yet, but the 1-2 seems better. could just be a band aid. Im going to take out the valve body and check the valves and see if any are sticking. Checked the fluid again this morning and its perfect. So I guess im not convinced the clutches are burnt. lol
Don't bother checking the valve body, there is only one solenoid and one valve lineup involved in the 1-2 shift, it would be super obvious in the log if there was any kind of valve drag. Also, the computer would notice it looking at pressure switch #3. Those high energy friction plate can take a fair amount of slipping and not burnt, they do drop their coefficient of frictions but if you can compensate in the tune you might be able to avoid going in there for quite a while. I would not call it a bandaid, if you can get it to have a clean 1-2 shift with tuning, it is a fix in my book.
Robert Moreau
TransGo
Am I correct in adjusting the oncoming pressure preset for the 1-2, since the computer is ramping up pressure to make the shift? I have all the parts sitting here, but you are right. If I can fix it for a while then im fine with that lol
Robert Moreau
TransGo
Heres the latest log. It seems to be shifting quicker and better, but like you said the 1-2 shift isnt a real seat of the pants type feeling. Havent had any flares on the 5-6 shift. And in this log I made sure to leave steady throttle when the shift happens.
24-10-08 12-56-24.hpl
Robert Moreau
TransGo
