Results 1 to 9 of 9
Thread: Boost referenced setup on E38
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    312
    Ran out of injector running E85 and want to stick with my ID1000s till winter and might spring for a new set of ID1300s.
    I have an Aeromotive 1:1 regulator connected to the charge pipe, before the throttle blade and set my base pressure at 60psi.
    Running Speed density and VE is tuned in pretty well already.
    My understanding is to copy the IFR value for 413 kPa (60psi) and use that for all higher kPa values since the pressure differential will now be a constant 413 kPa
    I also set IAT, MAP and Flow multipliers to 1.00
    Assuming this is correct, will VE need to be re-adjusted running in boost? Not that I mind doing so, just want to know what to expect and what to watch out for after making this change
    2012 C6 Base, Kooks 1-7/8" LT, Catted, NPP
    Novi 1500SL, 10% OD IW, Big Blower Cam, Flip Drive, 2x Alky, ID1000
    Nitto NT05R 305x19, 255x18 on CCW T10s
    Self built and tuned https://www.youtube.com/watch?v=Kod2UTqrVwM
    Nov 2017
    2,239
    I'm pretty sure you need your reference after the throttle body. Pressure in the intake/at the injector will be different there than before the throttle body.
    Advanced Tuner rabbs88's Avatar
    Jan 2023
    NY
    302
    Quote Originally Posted by NJ_Phil View Post
    Whatever you set your regulator to with he reference line unhooked is what you want to use for the value, then copy it to the entire table. Not just the values above. Also I believe gtstorey is correct about reference line placement
    Jul 2020
    VIC Australia
    1,506
    Yep correct, needs to be plumbed into the intake manifold. This will likely require a fuelling change at low load after correcting.
    E67 scanner channels ECM TCM Combined
    Want a cunt of a response, then write a shit post. It's a simple formula; Short preamble + problem statement + attempted resolution + pertinent build specs + tune + succinct data log with correct channels
    Jan 2014
    Australia
    2,027
    also the same IFR column u use 413kpa also use that column in the offset/volts/pressure table values and copy to all other columns
    Jul 2016
    Flanders nj
    312
    Thanks guys...
    07GTS:
    "also the same IFR column u use 413kpa also use that column in the offset/volts/pressure table values and copy to all other columns"
    So if my IFR value for 413 kPa is 118 lb/h, copy that to the Offset vs Volts vs Map?
    Doesn't sound right, maybe I'm misunderstanding you
    Jan 2014
    Australia
    2,027
    just use that same pressure column that is already in your offset volts press and put into all others, same as what u done with the IFR just to that other table, what ur base key on engine off fuel pressure is column goes into all others also, same as IFR
    Jul 2016
    Flanders nj
    312
    Got you... Thanks man
    Jul 2016
    Flanders nj
    312
    Works great. Thanks.
