Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Max Demanded Throttle Voltage (44389)
    Banned
    Jan 2022
    fountain valley
    2,379
    Wow wait
    You’re saying that using an updated version of scanner that the values in the table changed???
    Advanced Tuner Stoopalini's Avatar
    Nov 2023
    Central Texas
    417
    Wow wait
    Not scanner, but editor.
    Using an updated version of VCM Editor, the values now look correct ... yes, although the axes still look wrong. I've sent another message in asking about it, so we'll see.
    I have been pretty confident this whole time they had some mappings wrong, and now I wonder how many other tables may have had similar mapping issues. I've been combing through the calibration file, trying to see if I can identify any other areas ... but I can't do a compare of course, since you can't compare files across different versions of VCM Editor.
    I may install the older beta on a separate computer and do a tab-by-tab comparison to see what (if any) other areas may also be impacted.
    2023 Dodge Durango R/T (5.7L) with Tow & Go Package (build thread)
    Gen 5x Whipple 3.0L Supercharger
    Smooth Boost Electronic Boost Controller
    SRT 392 Air Intake Conversion
    92mm Hellcat Throttle Body
    Mighty Mouse Mild SRT Catch Can Setup
    Banned
    Jan 2022
    fountain valley
    2,379
    Of course I meant editor - smoked
    Every once in a while my mouth waits for my brain : )
    I use Windows 10 a bootleg version with absolutely no One Drive cloud nonsense and can compare across editor
    Scanner is different and sometimes I need to back up for a log to load
    Updating The VCM suite should not change any of your tables
    Nov 2023
    Central Texas
    417
    Well, it did change the values. I even loaded the old beta on a different computer and loaded the same tune file to compare. The values in this table are definitely different between the previous beta versions and the latest.
    All my computers are Windows 10 (not bootleg) with no one-drive on any of them.
    The values changed because they had the translation mapping wrong.
    I also now have access to Barometric Pressure characterization fields on the AIRFLOW tab, which I didn't have before.
    Also have a few other things available too ... Haven't had time to dig through it all or try a new load or log yet, but hope to tonight.
    Nov 2019
    312
    Quote Originally Posted by Stoopalini View Post
    Now, the table shows reasonable values in the cells but the axes still looks wrong.
    Attachment 152971
    That looks fine to me. Now to check if it actually works.
  6. #26
    Nov 2023
    Central Texas
    417
    Quote Originally Posted by HaasExp View Post
    Yep, agreed.
    A recent log does show throttle voltage ramping with RPM when pedal voltage is constant.
    This picture also shows (what I think is) torque mgt pulling throttle during shifts when not at WOT, but I'll start another thread related to that topic.
  7. #27
    just on that table pot all the values on 4.0000 but leave the first one
