Results 1 to 8 of 8
Thread: The lowdown on widebands?
    Aug 2024
    28
    I?ve been looking around in the forums and internet on the topic for a while now, and was wondering if someone could give me some more info on widebands.
    So essentially, are there pros and cons, similarities and differences with Lambda vs AFR?
    I’ve seen all the Bosch 4.2 and 4.9s, along with NTKs. What’s the ideal sensor in terms of cost and performance? I’ve read the NTK is relatively more durable than Bosch and that it’s actually considered “lab grade” but that’s all I’ve really gained.
    What about the best brand/controller/gauge on the lower prices ranges
    I’m aware of AEMS, Ballanger, NGk, PLX, etc but haven’t really seen any clearer answers which would be expected as I’m sure they are all good in many ways?
    Lastly, and a bit more specific, if I want to utilize a 14point7 unit, what’s everything I would need to put one of those together? Like what controller board sensors etc?
    If there’s a thread that covers this entirely or just one of my questions, would be greatly appreciated to be able to see.
    13,860
    I've never once had a problem with the AEM widebands using the 4.2 and 4.9 sensors. They are very accurate for what they are.
    I can switch either to be using Lambda or AFR. For most it's all a personal preference but Lambda is generally easier because Lambda is Lambda is Lambda if you get what I mean.
    Sep 2021
    Kentucky
    1,269
    If you plan on doing many cars, especially power adder/methanol, etc. Go with ballenger in a ntk sensor. AEM x-series are fine for light duty use. 14point7 seems to be good so far, i have duals on the dyno.
    Oct 2004
    357
    If any part of your first sentence was true you would already have your answers.
    Aug 2024
    28
    I’m also relatively interested in personal experiences with such, not just data
    Mar 2022
    Indiana
    3,965
    My AEM went bad in about a year. I don't like them, but it's cheaper to keep putting sensors in than to buy a new unit from someone else. Bosch O2 sensors, narrowband and wideband, are garbeege.
    As far as gauges, I prefer AutoMeter.
    Mar 2009
    Andover, MN
    724
    NB's, i can see that. buuuut.
    https://forum.hptuners.com/showthrea...ving-Into-2020
    Mar 2022
    Indiana
    3,965
    Quote Originally Posted by ns158sl View Post
    buuuuuuuuuutttttt
    "AEM Performance Electronics (“AEM Electronics”) warrants to the original consumer that all AEM Electronics Products will be free from defects in material and workmanship under normal and proper use for a period of 90 days from the date of the original purchase."
    https://www.aemelectronics.com/help/
