Results 1 to 3 of 3
Thread: 2005 Dodge Magnum RT 6.4L engine swap VCM Scanner issues.
    Oct 2024
    I have a 2005 Dodge Magnum RT with an early build date, and I've completed a 6.4L engine swap. Recently, a remote tuner provided me with their Dodge Pre-2012-2023 channel file.
    I've noticed a pattern: the channels ending with (SAE) do not initially generate data. Here?s the process I follow while the car is running:
    1. Connect
    2. Repoll for Supported Parameters
    3. Start Scanning
    During the same recording session, to populate the other non-SAE channels, I perform the following steps:
    Resync Interface
    1. Click the "i" button under VCM Suite Info
    2. Enter the MPVI2 Verification Code
    3. Once the data for the non-SAE channels populates, the initial SAE channels' data freezes. This means I can access all the channels, but not all simultaneously.
    Interestingly, when I connect my MPVI3 dongle to a 2017 Jeep Grand Cherokee, the VCM Scanner successfully pulls data from all the Dodge Pre-2012-2023 channel files provided by the tuner.
    I've tried using three different laptops and various cables to troubleshoot the issue. Additionally, I created an HP support case titled "VCM Scanner Issue - #455050."
    Does anyone have suggestions on how to resolve this issue?
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    2,261
    what version of the suite are you trying to use?
    tuned by tank [email protected]
    Oct 2024
    At the time of this post, I was using BETA 5.1.3427. I am now using Beta Version 5.1.484, and I am still experiencing the same issue.
