Someone brought me a 2002 Sunfire with an ecotec 2.2 swapped in. That swap included a computer and HPT recognises it as a 2004 Jbody. (Can't remember if it says Cavalier or Sunfire). The car has a Hahns Racecract Stage2 Turbo kit installed.
The Hahns kit came with a BEGI FPR and 32lb injectors. The customer believes that the stock injectors were 24lbs. When he arrived we removed the BEGI and installed an AEM 1:1 FPR set at 43 PSI. I Installed HPT on it. The engine had a 1 bar MAP sensor so we scrounged up a replacement. A 1.7 bar sensor from a honda was used. These have proven to register to 10 PSI reliably.
I scaled the tables as per instructions on this site. Now the car will not stay running on startup. The cranking fuel is correct as adding to the cranking VE causes the cranking fire to feel very rich. As soon as it exits the cranking mode I assume it will move to the idle fuel table.
I tried changing the injector factor from 1.7 to a variety of lower values without any luck. So I disabled closed loop mode and set the target idle to a variety of spots. The car will start and run if he pumps the throttle while cranking. I have a feeling that the afterstart enrichment is wrong. I leaned out the mixture at a variety of idle points to develop a reasonable idle VE table. It now idles at from 13.8-14.5 from 1500-700 RPM.
It still dies on startup. The idle control also has too much authority on timing as it will go anywhere from 0 to 24 degrees trying to maintain a good idle. Normally I disable timing changes during fuel idle tuning. No such feature here. The idle quality is fairly poor. Generally I'd like to see +- 6-8 degrees of authority here.
Unfortunately the main fuel tables are based on an alpha-n strategy which is not good for a turbo application. There is nothing available to change this So driving I dialled the VE table in a little to provide a conservatively rich fuel strategy at low throttle positions allowing the closed loop to trim it up to stoich for fuel economy. I set PE mode to come on very agressively. As soon as he leans on it and starts making boost it drops to the desired 11.5AFR- except at higher RPMs but I haven't figured how to properly adjust that yet but it's still within safe limits.
Tuning with the system was absolute hell and has taken more than 15h of work. The VCM editor has a number of bugs and throws the occasional index out of range exception. (I will report that as soon as I can reproduce it properly). The scanner doesn't seem to support anything useful. There is no real time tuning. I played with the histogram feature for almost an hour but can't stop it from saying unsupported on every page. A few small VCM editor changes would go a long way. I'd love to see the ability to scale the concept of MAP for a larger sensor. It's only a display anyway. If only the scanner and editor could talk to each other and show me where in the map it is!
Right now if I didn't have a lineup of other cars to tune I'd start dumping out the calibration files and disassembling them myself to find the proper settings.
Can anyone offer suggestions? Maybe there is another VCM that would be better supported on the ecotec?
-Michael
