Results 1 to 12 of 12
Thread: ngk 6510 suck
    Jun 2012
    Canada
    160
    ngk 6510 suck
    lt4 making 18.5 psi 1100rwhp and the 6510 plugs suck. they fail so easily if you run them hard for a long time, without any sign of damage. they run great with no load but when full throttle start misfiring. take them out and it is so difficult to tell which plug is failing. all read between 4 and 6 ohm good reading but there definitely a problem. Even did a full throttle dyno pull and shutdown engine still can really tell which one fail. even try IR image but difficult to accurately read between cylinders due to header wrap. Yes plugs are gap at 26 so not blow out spark.
    Is there a substitute for 6510. would love copper plug but i don't think anyone makes one
    Senior Tuner 04silverado6.0's Avatar
    Sep 2021
    Kentucky
    1,739
    You try adjusting the dwell time?
    Jun 2012
    Canada
    160
    thanks for the response yes i have to no avail i do not want to get too aggressive with dwell last thing i need is failed coil. put new plugs in and it runs great. i realize also these plugs can be counter fitted. i always validate them by sending picture the ngk. my problem they just don't last. Any other plugs you know of i can try? seems limited info on replacement to 6510
    Jun 2012
    Canada
    160
    at 890 rwhp never had an issue with these plugs lol
    Sep 2021
    Kentucky
    1,739
    Probably dont need to go too far on dwell, these coils should be great. I do not have a plug recommendation but someone on here should.
    Jun 2012
    Canada
    160
    4.5 ms at the average running voltage still failed after about 30 5 gear dyno pulls dailing in 45% port injection. the fuel mixture wasn't that off to damage the plugs. Side note, I went as far i can go with fuel injector multiplier 3 so that i don't skew my air mass model that much, because 45% removal of stock ecu is a lot to ask. Going to far on multiplier 3 started to affect specific transition area of part throttle by PW fluctuating between 2700& 3000rpm. Most people would tolerate it but I needed to drive exactly like stock .2018 ctsv built separate fuel tank with ethanol one R dedicated to port only for wot. Wanted, Direct injections below 4ms to add also e85 to main tank and test spraying 100 or more by modifiing tune to accept spraying and to remain higer than180 degree eoi. Sorry long winded. Never got there due to these plugs. Goal 155+ trap speed. Really bummed out with this failure
    Jun 2012
    Canada
    160
    Here's my findings if anybody else is looking
    Aftermarket iridium same heat range
    NGK LTR7IX11 6510
    DENSO ITV22 5340
    BRISK RR14YS
    FORD PERFORMANCE M-12405-20T
    AUTOLITE XP5263
    I decided to go with the denso which are pre gap at 32 and have the same heat range of 6510. If you're picking any other plug from this list please do your research
    Cheers
    Aug 2006
    Arizona
    365
    For 1000hp+ builds with a lot of heat (half mile competition) , I like BRISK RR12S
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Aug 2006
    5BA8
    5,282
    Definitely the Brisk plugs. I'd never be using a projected tip plug at that boost and HP level to begin with.
    Edit: What kind of "damage" are the plugs showing? You blowing the tips off? Damaged plugs to me says back it down some.
    EFI specialist
    email=[email protected]
    Oct 2021
    Orange County, CA
    46
    Quote Originally Posted by obd2 View Post
    im on the 4554 V's and seem to like them fine. haven't been able to get on it yet - dealing with other issues but feedback from others on them is good?
    Aug 2006
    5BA8
    5,282
    Quote Originally Posted by lippmoney View Post
    You're running those plugs in an LT engine?
    EFI specialist
    Aug 2020
    Petersham, MA
    146
    What do you guys think of the NGK Ruthenium HX plugs?
    EDIT: looks like heat range 6 is the coldest heat range I can find. Probably not cold enough for 1K WHP and near 20 pounds of boost.
    2017 Camaro SS, Whipple 3.0, Mast LT Black Label heads, 112mm TB, LPE BB HPFP & LT4+52% injectors, Fore Innovations triple pumps
    1059 WHP, 944 WTQ ; 9.10 @ 153
