Guys,
Any suggestions would be appreciated. I'm working a 2011 Escalade with twin turbos installed at about 9 psi boost. The engine is stone stock otherwise with the DOD locked out but the hardware still in the engine. The cam phaser is still active. This thing has been a total PITA compared to other builds I've done. I've had a misfire issue from the beginning. Wires have been an issue so I finally threw the kitchen sink at it with Moroso Ultra 40 wires, ceramic boots, fire sleeve and fiberglass wrap on problem wires. The wires seem ok now, (TF).
I'm still getting random misfire at 7 psi boost and up. As soon as I'm off the throttle, it comes back, runs fine and the CEL goes away after coming on during misfire. The plugs are AC Delco double platinum 1 step colder plugs gapped at .026" (factory is iridium). List of changes include:
1. 2.5 bar MAP
2 Turbo exhaust manifolds
3 Plugs and wires listed above
4. Intercooler
5. 2 Factory air filters
6. 2 T3 T04E turbos
7. Cast down pipes into factory cats and exh
I'm about ready to go one step colder iridium plugs gapped at .022" to see if there is something there. The only other thing I can think of is exhaust back pressure. The front cats are in, active and have no face melting. The tuning has been straight forward minus the misfire.
Any known solutions or ideas would be appreciated.
Thanks,
Aaron
