I have a 2002 Silverado with a 4.8. The motor had a bad rear engine bearing so I got a new motor. It is also a 4.8 I put it in and added the electric fans as a upgrade as well as a ported TB and cold air intake and headers. All the sensors are new Crankshaft position sensor, Camshaft position sensor, throttle body position sensor, ERG valve, and injectors. I was able to tune the vehicle to accept the electric fans and get the truck to start but the biggest issue I'm having now is it now develops a p0200 code. I'm not sure if it has to do with the new injectors that we put in the injectors that were original were working fine well at least for me and I tried to order new ones and they were discontinued so I went with the AC Delco 25317628. They were supposed to be the updated version. Please i need help where on what else i can go to make it run right. I was told that one of my injectors may be misfiring so I went ahead and pulled each one they are all pulling 10 homes so that eliminated the Injectors from being faulty I also checked all the wiring to make sure that they were all getting current when the vehicle is running and I have also made sure they are all getting spark from the spark plug wire. Here is my file 2002silveradoOME.hpt
