Thread: 08 to 03 Silverado tranny swap
    Nov 2024
    Minnesota
    Im trying to put an 08 tranny in my 2003 Silverado I read a forum that said that the plugs are the same just the extra connectors for the iss if my Tcm isn?t looking for the iss will I still have issues with torque converter lock up? I?ve heard that you can just plug it in and it?ll work and I?ve heard that you?ll have shift issues and lock up issue just looking for some foresight, thanks
    Aug 2023
    SoCal
    668
    Quote Originally Posted by bart06 View Post
    It will work just fine. The other way around is what causes issues.
    Robert Moreau
    TransGo
    Nov 2018
    Middle TN
    96
    I did a swap similar to this, the only difference I had was the turbine speed sensor in the front pump housing on the later model trans didn't get used. Truck still goes hard 3 years later. Just make sure you clean out the cooler lines good, then extra good, then do it again....
    Mar 2025
    North Idaho
    14
    im trying to find information ANYWHERE about using a 4l60e from a 2012 gmc sierra in my 2004 tahoe. would it be the same?
