here is how it looks now after i wrote the revision. This was just a short drive around the block and i must say it even felt good however, I noticed that you have me in open loop. Is that on purpose? Shit man! Ill leave it in open loop until it dies if you think that is how I should leave it. My wide band is an AEM 30-4110 and that is an option in the scanner to choose when setting it up so i believe it to be true. Should i keep tuning the vve with your assistant program using the open loop eq error?
cringer.hpl ...Thank you Dan for taking the time to help me out. I am truly thankful
