Results 1 to 2 of 2
Thread: Has anyone done a setup like this before with the Cmd torque delta table
    Jan 2024
    the moon
    9
    basically no negative numbers, could this be beneficial for performance setups or cause damage?
    Mar 2024
    DMV
    28
    based on my understanding this will likely cause damage or maybe some kr, the column axis being rpm error, you should have negative values to the right when its too high to correct and should be positive to the left when too low
    I believe your looking for virtual torque if you want to modify how much torque your car will request at different rpm, airmass, and spark
