Hi all, does anyone have a base tune for a 2002 C5 Z06 Corvette w/ Gen 3 engine harness wiring and ECM but with a LS3 495hp GM Crate motor? Just to get it running.
All stock engine except headers, No cats, 2 forward O2 sensors only, GM LS2 throttle body, GM stock 430hp injectors, stock fuel pump and Vararam intake. THX Brian!
* Compression ratio of 10.7:1
* Recommended fuel is 92 octane
* Cast aluminum block with 6-bolt cross-bolted main caps
* Nodular iron crankshaft
* Powdered metal connecting rods
* Hypereutectic aluminum pistons
* Steel hydraulic roller tappet camshaft
* Valve lift of 0.525 in. for intake and exhaust
* Duration at 0.050 in. is 219 degrees intake and 228 degrees exhaust
* Lobe separation angle is 112 degrees
* Combustion chamber volume is 68cc
* Valve diameter is 2.165 in. for the intake and 1.590 in. for exhaust
* Cast roller trunnion rocker arms with a 1.7:1 ratio
* Internally balanced
* 58x Gen IV reluctor wheel
