That's very interesting have you found away to match up turbo airflow vs desired Turbo airflow?
Ive tried to line those out to stay close but hitting a wall... and they deviate quite a bit.
Whats the highest inferred turbo speed you've hit at higher rpms?
No I haven't been able to get the flow numbers to match. The highest speed ive seen is 430k
boost update
so heres how i have my settings for the min/max vs. airflow, i can hold 20psi up to 5500ish RPMs and hold 18-19psi at 6000+.
this is at 5500 FT of elevation with D.A. being 6000ft+
im confident that if i set the min vs turbo airlow to 20psi @ 40lbs/m, that ill be able squeeze 19-20psi on the top end.
you have to make sure your map vs. map desired, amd turbo airlow vs Turbo airflow desired all line up.
Screenshot 2025-01-22 232351.png Screenshot 2025-01-22 232418.png Screenshot 2025-01-22 232617.png
