Ford Focus GM5A Strategy Datalog PIDs
I'm currently on SCT platform, and am having issues with datalogging certain PIDs. My ECU strategy is GM5A. I need to know if HPTuners supports datalogging these PIDs with the GM5A strategy. If they can I may end up switching because SCT is not doing anything to add the ability to add these PIDs into their datalogging software.
I need these PIDs (name doesnt have to be the same, as long as the PID is the same):
Ambient Air Temp
Barometric Pressure
Engine Coolant Temp
Fuel Rail Pressure
Knock Sensor 1
Knock Sensor 2
Knock Sensor (Global)
Load
MAF Frequency
Measured AFR Bank 1
RPM
short Term fuel trim bank 1
Spark Advance
Throttle Angle Actual
Throttle Angle Desired
HDFX Fuel Weighting Factors (all of them)
Final Torque in Nm
I do not currently own an HPTuners MPVI3 tool so I cannot test if these are able to be datalogged. If anyone from HPTuners can shed some light on this, that would be great. Thanks!
