Results 1 to 5 of 5
Thread: EQ Commanded HELP 2018 Hemi 5.7L VVT
    Nov 2024
    15
    I'm new to the forums and started my tuning journey about 6 months ago. I am tuning my 2018 Ramm 1500 5.7L VVT Rebel. It has a custom intake, JBA shorties, and SOLO Performance Cat back exhaust, ADF E-85 conversion kit and FIC 525 injectors. I was feeling like I was finally getting a good grasp of tuning THEN I saw the trend of my commanded EQ Lambda at WOT. I'm seeing the commanded lambda at 0.928 at the start of a WOT pull, then after the shift it gets rich 0.674. My FA Stoich is stock 0.0720 and the FA PE table is set to .0056 across the table. From my understanding my truck should commanding ~.873 at WOT. What would cause the commanded EQ to be lean then swing so far the other direction?
    Advanced Tuner Stoopalini's Avatar
    Nov 2023
    Central Texas
    407
    Maybe something with the exhaust temperature protection FA Enrichment? Tables 44457, 34270, 34273
    Add the Catalyst Temp and FA Enrichment channels to your logging and see what FA enrichment is being commanded and compare it to the cat temp to see if it aligns.
    2023 Dodge Durango R/T (5.7L) with Tow & Go Package (build thread)
    Gen 5x Whipple 3.0L Supercharger
    Smooth Boost Electronic Boost Controller
    SRT 392 Air Intake Conversion
    92mm Hellcat Throttle Body
    Mighty Mouse Mild SRT Catch Can Setup
    Nov 2024
    15
    @stoopalini You nailed it! Looks like I'm running hot and the enrichment kicks in to save the Cat and O2 sensors. See the attached log. I'm going add more fuel in the PE Table and see if that helps. I'll post the results in the next reply.
    Nov 2023
    Central Texas
    407
    I'd also check out your IAT wiring, as for some reason it's reading -83*F.
    Nov 2024
    15
    I double checked the wiring and reseated the sensor. It didn't make an improvement. BUT I had a thought and double checked the Channel. I removed the IAT and added the IAT (SAE) channel and now it is working. I appreciate you weighing in on this and helping me get better. You rock!
