I am at the end of my rope trying to solve a misfire on #8 which only happens after three or four WOT highway speed mashings if done within a short period of each other where I kick down a gear and wind her out a bit..
No valve train or compression issues. Swapping coil pack, spark plugs, and injector to the other bank does not move the the issue.
Only PO308 code is tossed. Wiring harness checks out.
Sometimes it will run rough, but 95% of the time its just the code. If running rough, I can turn the car off and back on again and it will run smooth, I can clear the code before or after or later it don't matter.
I want to try an ECM replacement. I need a trustworthy source that will program my VIN to it and anything else required. I take it I would then back it up and flash my tune onto it?
