Results 1 to 20 of 20
Thread: Where Is The Best Place To Buy an ECM? 2013 Charger R/T
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    549
    I am at the end of my rope trying to solve a misfire on #8 which only happens after three or four WOT highway speed mashings if done within a short period of each other where I kick down a gear and wind her out a bit..
    No valve train or compression issues. Swapping coil pack, spark plugs, and injector to the other bank does not move the the issue.
    Only PO308 code is tossed. Wiring harness checks out.
    Sometimes it will run rough, but 95% of the time its just the code. If running rough, I can turn the car off and back on again and it will run smooth, I can clear the code before or after or later it don't matter.
    I want to try an ECM replacement. I need a trustworthy source that will program my VIN to it and anything else required. I take it I would then back it up and flash my tune onto it?
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    2,282
    i would call flagship one and find out 1) if they had my part number and 2) what revisions of my os they could flash that part number with
    Jun 2009
    N. GA
    549
    Thanks. What will they think of me flashing my supercharger calibration on it? Warranty voided?
    Jan 2022
    fountain valley
    2,282
    dunno...
    usually people who supercharged a hemi are not concerned with the warranty for a $200 box
    Jun 2009
    N. GA
    549
    Copy that. I ordered one this AM. I've never did a ECM swap.
    Is it as easy and backing up my current tune, disconnect battery, swap them out, reconnect battery, turn the key to on and do a full read backup of the new ECM, then do a full write of my modded tune?
    Jan 2022
    fountain valley
    2,282
    if yer modded tune is from a pcm with a different serial number (or a different os revision) you will not be able to write your old tune to the new pcm
    vin serial number and revision gotta match
    if not, it wont even start to write
    tuned by tank [email protected]
    Advanced Tuner Stoopalini's Avatar
    Nov 2023
    Central Texas
    407
    Hmm ... I have two PCMs with different part numbers (the original from my 2023 Durango and a spare I bought out of a 2021 Grand Cherokee), and I've written the same tune file to each without issue.
    They are GPEC2a PCMs though, and I did have HP Tuners unlock both of them .... and sent them my stock OEM read file for the unlock of the donor. So maybe that allows me to write the same tune files to either PCM without issue?
    If you can't write the tune though, I suppose you could create a template file with all tune categories checked, and then write that to the new PCM.
    TOOLS -> TEMPLATE EDITOR -> NEW FILE -> SELECT PARAMETERS TO IMPORT
    Then check all the boxes (except for the OS box maybe?) and save the template file. You should then be able to apply the template to the new PCM and transfer everything over.
    EDIT: Oh, never mind ... I just tried this and the template functionality is limited to 1000 parameters. So I guess you'd have to make several templates and apply them one at a time to use this method.
    2023 Dodge Durango R/T (5.7L) with Tow & Go Package (build thread)
    Gen 5x Whipple 3.0L Supercharger
    Smooth Boost Electronic Boost Controller
    SRT 392 Air Intake Conversion
    92mm Hellcat Throttle Body
    Mighty Mouse Mild SRT Catch Can Setup
    Jan 2022
    fountain valley
    2,282
    all the different operating systems will not work in all the different jpec2 controllers
    that is why it is recommended to use the same part number when flashing and replacing a controller
    there may be many part numbers that will work with his os but do you know what they are?
    i do not
    Jun 2009
    N. GA
    549
    Many Thanks. In saying it will not write, do you mean absolutely, or will I at least be able to enter settings manually?
    Nov 2023
    Central Texas
    407
    i do not
    Not sure, I just used online Chrysler parts websites to check the part numbers I was considering for a donor PCM, to see if they were compatible with my VIN.
    Certainly using the same would be preferable, and for a 2013 MY, should be easy enough to source. My vehicle was new enough at the time where I couldn't find the same part number though, so had to go with a different one.
    Jun 2009
    N. GA
    549
    Jun 2009
    N. GA
    549
    Flagship sent notice of the part number they are prepping and it matches mine.
    P05150696AC
    Jun 2009
    N. GA
    549
    Thanks Guys Finally got a tracking number. I'll let you guys know soon.
    Given it lets me copy to backup and write, is it as easy as?:
    • Backup current tune
    • Swap ECM
    • Backup Replacement stock tune.
    • Write current tune
    • See if she will start
    Jan 2022
    fountain valley
    2,282
    pm you
    Jun 2009
    N. GA
    549
    Copy
    Apr 2025
    I'm in a similar situation myself with a 2013 Ram 1500 that needs an ECM Replaced. The guy I've been doing remote tuning with has been ghosting me so I'm having trouble finding answers. Any chance you could offer some guidance?
    Any help is appreciated.
    Jan 2022
    fountain valley
    2,282
    years ago my wallet was $550 lighter and after just a few revisions my remote tuner threw his hands in the air and said: "What do you think i am.. an internet hemi mechanic?"
    my 2016 shaker was practically brand new (<10k miles) and he was certain the trans was toast - blocked me cuz i wouldn't pull it back out and send it and $6t500 to his trans guy
    today i get my used pcm's from flagshipOne
    there is another company, OEMAutoParts.com if flagship does not have the part number that i need
    with your controller being a early GPEC2 you may have to look around
    was your remote tuner tuning it with HPT?
    do you have a copy of the stock read?
    Jun 2009
    N. GA
    549
    My case is the driver for Cyl 8 was bad in the PCM. After three or more WOT runs it would misfire #8. Most of the time it would still run fine but show the code. When it did run rough a key cycle cleared the miss but not the code. I always have an OBDLink dongle with me and clear the code at 1st opportunity.
    All efforts to make sure it was not a cam and or lifter issue was done previous.
    I got a Flagship PCM
    1. Read the New PCM.
    2. Did a Compare of new PCM file read with my tune file in VCM Editor.
    3. Copied over the changes to the new PCM file.
    4. Wrote the new file to the new PCM.
    Fixed.
    Nov 2023
    Central Texas
    407
    Quote Originally Posted by 2therock View Post
    Fixed.
    Great news! Thanks for updating the thread with the result
    Apr 2025
    Sent you a pm.
