Hello everyone, I have the following problem.
I have adapted the LS1 control unit to an old engine with a manual gearbox. The engine runs and you can also drive.
But now I have the problem that under full load at approx. 5000 rpm the engine suddenly shuts down. What I have not installed is the VSS and the clutch switch and I think that the engine only runs in the idle table. Which sensor or which signal is responsible for this? Is the reason for this the missing clutch switch or the VSS?
Any and all help would be welcome. Thank you
