Results 1 to 5 of 5
Thread: Bucking at low loads
    I am working through the tune on my gen 2 Coyote swap and I am experiencing bucking during light load cruise. I notice that when at light load the exhaust cam phase angle goes to 40 degrees. While it is in this position, you can feel the car "bucking" like it has a cam with allot of overlap. the misfire counter starts going up as well. If I decelerate or accelerate the cam goes back to 0 degrees and smooths out. i have IMRC locked open with an 18 intake. Can anyone look at this and see if there is any glaring problem?
    I believe that it is being caused by the mapped points being used without IMRC. I just made changes to the distance tables and mapped points to see if this helps.
    Mar 2019
    427
    Did your swap end up working without disabling PATS?
    Quote Originally Posted by B E N View Post
    The control pack strategy? It did not. No start. I looked at it with FORScan after loading it and it came back with corrupt database. I am still having problems that I am trying to sort out. It appears that the PCM is loosing it's non-volatile memory. The HPTuners crank relearn does not appear to work. If I use FORScan it works (no cylinder 4 and 7 misfires). But if i let it sit for an hour, I have to do a crank relearn again in order for the misfires to go away. Strange.
    To close the loop on this thread. I believe that I have the issue resolved. I looked at my logs and compared cam positions to a gen 1 configuration (they don't use IMRC). In the area that I was having trouble (Fuel Economy), the gen 1 has both cams at 0 deg and about 35 deg of timing. I configured mine to use tables 14 and 15 only while in Fuel Economy and the surging completely went away. Seems to transition to Optimal Stability smoother as well.
