Dug through the forums and found a user with exact issue. No resolution posted. Did reach out in PM so hope to hear back. GM performace LS3 connect and cruise package. Transmission randomly has no forward gears at first startup in the morning. Can disconnect and reconnect the bulkhead connector for the trans, and transmission immediately functions normally. GM performance techs havent been much help. Want to replace the Trans as unit due to the connect and cruise diag cable being married to the TCM and the cable is no longer available. Any one else with this issue or can lend some insight. Prior to unplugging I did verify trans is showing commanded state for gear section.
