I'd like to add flex fuel option to my 2004 Sonoma with the 4.3 vortec V6 MPI. Its PCM is the green/blue P59 running OS 12587603. The PCM has the capability of running flex with the composition sensor and DBW even though it is DBC. To my knowledge, none of the s-trucks were available with Flex. My question is: is it as "simple" as adding the input pin from the comp sensor to pin 57 on the PCM and enabling flex option in the fuel tab and copying in the alcohol values into the alcohol EQ table and Blend table? Or, will the engine management parameters not allow composition input because it won't "look" for that input? Thanks in advance for any input.
