Results 1 to 4 of 4
Thread: How To Change Shift RPM? 6r80 2014
    Jul 2024
    7
    Question How To Change Shift RPM? 6r80 2014
    I?ve been trying to tune a 2014 f150 to shift at 6500rpm and can?t seem to make it happen at the desired rpm. It seems to shift somewhat whenever it feels like. Why?
    Changing 1-2 shift (speed vs TPS) higher does not help and neither does Shift rpm WOT. I?ve tried with and without shift rpm anticipation with no change.
    Do I need to move the rpm limiter up? Is the truck thinking it cannot fulfill the shift when commanded so it just shifts when it wants?
    Greedy Tune 17 high timing File Duane F150.hpttune 17.hpl
    lowered the max acceleration:
    Greedy Tune 19 high timing File Duane F150.hpttune 19 pull.hpl
    raised max accel plus raised shift rpm wot and raised clutch fill time 1-2
    Greedy Tune 21 high timing File Duane F150.hpttune 21 pull.hpl
    Id love to hear murfie or erics input on this!
    Advanced Tuner Lost0187's Avatar
    Oct 2021
    Canton Ga
    237
    You will need to increase the max shift speed max shift RPM to start. There are a few other things as well Ill take a look and send you a revision. Also what size wheel tire combo are you running on the truck? Is the rear differential 3:31 or has it been modified?
    King Ranch Expedition 5.4 3v 6R80 Coyote PCM , M112 Blower, Kooks Long Tube Headers, Green Cats, Aeromotive Regulated Return Fuel System, ID 1000 Injectors, Custom Interior Wiring, Track Apps, EPS mode adjustable, +6 Blower Pulley w/ Innovators West SFI Balancer, Afco Dual Fan ZL1 Heat Exchanger, Flex Fuel E85 0-60 5 secs 12.0 best quarter mile time.
    14 GT500, 13 Mustang Custom, 03 Aviator 4x4, 16 Navigator Reserve 4X4
    Oct 2021
    Canton Ga
    237
    Try this out ad see if you get the desired 6500 shift
    Yak Update Nomal Shift 6500 RPMS.hpt
    Jan 2020
    10
    Ever get it?
