Injector coding
Hello I have a comp cammed 2000 mustang gt auto car with a vortech v2 supercharger, lu47lb injectors (ford performance), a 340lph pump and a sct3000 blow thru maf.
I need some assistance in regards to inputting injector data any tips?
Not exactly sure what you're asking with regards to injector coding, so please clarify if I'm off base. Assuming injectors are the only change you're making and you're still running stock rail pressure (~40psi) in a returnless config and you're not trying to tune for all of the above changes at once, input injector specs (high/low slopes, breakpoint, and offsets) as per data sheet. With a known good MAF curve, it should be fairly easy to dial the slopes in further if needed
