Results 1 to 3 of 3
Thread: Would a VVT Limiter cause a P000B DTC
    Jun 2024
    24
    2019 Ram 1500 Classic. Small Stage 1 Camshaft with a VVT Limiter installed with VVT Left on.
    When I Log:
    Exhaust Cam error it reads 0% but out 10 different cranks and start/run and approximately 30 minutes of mainly idle and rev for a split second it will read -25 degree exhaust cam error and go away based on about 10 logs I've recorded.
    Key on Exhaust Cam Centerline Position vs Exhaust Cam Angle is 128 degrees but once I crank/start/run vehicle they both read 95 degrees and 99% of the time I get Exhaust cam error 0% but once I rev it up above 2,600 rpm it gets a split second literally of Exhaust Cam error -25degrees and goes away. This is also not every time I rev it past 2,600 rpm its basically almost an anomaly.
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    2,267
    post your oem file as well as what you have in it now
    tuned by tank [email protected]
    Jun 2024
    24
    Alright
