Hi Guys,
Durango Tow N Go 5.7ci
Heads/Cam/Whipple Gen.5
Lightswitch effect since day one. in the attached tune, Boost does not come in until 115-120kpa Map.
When it comes on, its at 5psi already and in dramatic fashion. my KOEO map is 122kpa with the Hellcat 3bar.
I have cured the lightswitch effect by adjusting the map to read 101-102 KOEO, HOWEVER, The fueling is a bit of a mess (super high LTFT). After fixing the fueling, with my remote tuner, its back to lightswitch time.
I know this Durango T&G OS is not great, as I'm on my 23rd revision of a tune, But I have found the happy place(with changed map), then it was gone soo quickly.
The tune Attached is Rev.22. which has the original 3bar Hellcat map setting.
I'm just trying to find the happy place again, Where the boost is there when you press the pedal, not waiting behind a curtain to attack you and your family!
The attached log file are 2 very short, however, there isnt any positive boost during that short run
